Civil 3D Toolkit Feedback thread
That’s interesting, I’ll add it to the TODO list, thanks
Hello all, thanks for all of the recent updates. I have one question (bit embarrassing), I really can’t see why the following script to swap multiple parts is not working, is there something I am missing? Structure diameters won’t change, but the part size selected is a different one from the original…
Any help would be appreciated, many thanks in advance!
@v_rivas Civil 3D Toolkit Feedback thread - #630 by Paolo_Emilio_Serra1
The TkCorridorFeatureline.exportaspolylines node is returning polylines as per corridor start and endpoint stationing, not as the start and endpoint stationing from the TkCorridorFeatureline or corridor regions.
Is this by design or a not implemented feature yet?
by design, not going to change
Solved, the script works fine, it was a broken link with the part catalogue, apologies and thanks!
Hi, I am working with TK Subassembly nodes now. What is SubassemblyPoint.Station node purpose please?
I have subassembly from polyline in Civil 3D. I don’t understand why is 0 value there for every point. Is it possible to get offset from origin (subassembly or assembly)?
D4C3D_Corridor_SubFromPline_01.dyn (15.7 KB)
Hi Paolo,
Thanks for adding the Pick Point node.
It works well in Dynamo session but it doesn’t work when I run through Dynamo Player.
When I click “Change” in the Player, nothing is activated. Is there a reason why?
Thanks,
Hello Everbody,
I review all post and this is the only one with this topic.
I have same issue, someone solve it?
:open_mouth:Hello Paolo, which I did to get in there?
Maybe I wrote something wrong. English is not may native lenguage.
How can I fix that? I really apologize
Hi @davila.vanegas ,
I believe you must upload the civil3dtoolkit log file, which is located in your temp folder. Otherwise Paolo will ignore you and put you in his naughty list.
@Paolo_Emilio_Serra1 Hello Paolo, have you had the posibility to check the drawing to see if that might be the issue?
Hello , I have a problem with PolylineExtensions.GetVertices.
I attach the log file once I run the dynamo script. I 've got it from %temp% folder. I’ve change the .log to .txt
the message text is:
"Warning: PolylineExtensions.Error in GetVertices operation.
Failed to convert coordinate system.
A point, a part of a line segment, or a part of the region is outside the mathematical domain of the coordinate system.2
Thank you
Autodesk_Civil3DToolkit.txt (52.4 KB)
It says that the Coordinate system code you have defined in the document is “.” (just a dot). Select something valid
Apologies I don’t have a lot of time as of lately
No problem, I completely understand! Maybe it would be time for a Paolo_Emilio_Serra2 to help you. :wink:
Hi @Paolo_Emilio_Serra1 Apologies i know you are really on a tight schedule lately …but did got a chance to have a look at above issue ?
1.1.23 is out
no sorry
