Window WPF with work in Revit
Good evening! Please tell me if it is possible to create a script based on using Dynamo+IronPython with WPF, in which I give the output a list of elements, according to which the selection box is created, while the wpf window does not close and i can work with a 3d view, and then select the next selection box in the script window and again we work with it until the whole list ends. I ran into a problem, I don’t understand if there is any command so that window wpf does not close and there is an opportunity to work in Revit.
I think you’ll need to make an addin to achieve such an outcome. Dynamo tries to run the script completely, and whilst you can use packages like data shapes to generate forms, they typically dont allow you to continue working. Some inputs let you switch to revit to select model elements, but not keep working generally.
Many thanks! And tell me on what such an add-on can be made?
Visual studio and c#, typically.
Thank you very much!
I have a sample available here for WPF window creation with C# and Visual Studio. However, you cannot (currently) leave a window open in Dynamo while other things are happening. Dynamo is very sequential in its behavior.
See @c.poupin’s reply below.
You can use a non-modal form
an example with IronPython
test Wpf no modal form
import sys
import System
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Lib')
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\DLLs')
#import Revit API
clr.AddReference('RevitAPI')
#import net library
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
app = uiapp.Application
sdkNumber = int(app.VersionNumber)
try:
	clr.AddReference("IronPython.Wpf")
	clr.AddReference('System.Core')
	clr.AddReference('System.Xml')
	clr.AddReference('PresentationCore')
	clr.AddReference('PresentationFramework')
except IOError:
	raise
from System.IO import StringReader
from System.Windows.Markup import XamlReader, XamlWriter
from System.Windows import Window, Application
try:
	import wpf
except ImportError:
	raise
class MyForm(Window):
	LAYOUT = """
		<Window xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
			Title="Window2"
			Width="404"
			Height="419">
			<Grid>
				<Label
					Grid.Column="0"
					Grid.Row="0"
					HorizontalAlignment="Left"
					VerticalAlignment="Top"
					Margin="14,16,0,0"
					Width="130"
					Height="29"
					x:Name="ClickSelect"
					Content="Click to Select" />
				<Button
					Content="Close"
					Grid.Column="1"
					Grid.Row="0"
					HorizontalAlignment="Right"
					VerticalAlignment="Bottom"
					Margin="0,0,16,16"
					Width="96"
					Height="24"
					x:Name="button1"
					Click="button1_Click" />
				<ListBox
					x:Name="listBox1"
					SelectionChanged="listBox1_SelectionChanged"
					Grid.Column="0"
					Grid.ColumnSpan="2"
					Grid.Row="0"
					Margin="14,53,16,61" />
				<Grid.ColumnDefinitions>
					<ColumnDefinition
						Width="0.503474042268444*" />
					<ColumnDefinition
						Width="0.496202531645569*" />
				</Grid.ColumnDefinitions>
			</Grid>
		</Window>"""
	def __init__(self):
		self.ui = wpf.LoadComponent(self, StringReader(MyForm.LAYOUT))
		collElems = FilteredElementCollector(doc, doc.ActiveView.Id).OfClass(FamilyInstance).ToElements()
		collElems = sorted(collElems, key = lambda x : x.Name)
		for e in collElems:
			item = System.Windows.Controls.ListBoxItem()
			item.Content = e.Name
			item.Tag = e.Id
			self.ui.listBox1.Items.Add(item)
	def button1_Click(self, sender, e):
		self.Close()
	def listBox1_SelectionChanged(self, sender, e):
		itemId = self.ui.listBox1.SelectedItem.Tag
		print(self.ui.listBox1.SelectedItem.Tag)
		elem = doc.GetElement(itemId)
		uidoc.ShowElements(elem)
		uidoc.Selection.SetElementIds(List[ElementId]([itemId]))
form = MyForm()
form.Show()
Wow! I thought it was impossible. Thank you very much for this solution and science! This is great!
But unfortunally you cant run Transaction in Modeless form
For transaction, it’s necessary to use Event (idling-event or ExternalEvent)
Is it possible in Dynamo?
Can you show pls, How it looks like in IronPython?
Here some example with IronPython
