Dynamo script run in revit 2020 but cannot run in revit 2024
I have Dynamo script work normal in revit 2020, but dont know why cannot run in revit 2024, it said unable to find assembly “System.Windows.Forms.DataVisualization”
Maybe the problem is between ironPython and CPython3?
Interaction with winform_1.dyn (13.8 KB)
Yes.
You’ll need to revise the Python, provide the script here so others can help, or continue to use the IronPython2 package and love with the security issues / consequences thereof.
@jacob.small Thank you for your reply. I have attached the dyn file above for your reference. Or you can review script below:
Script
import System
from Autodesk.Revit.UI import*
from Autodesk.Revit.UI import Selection
from  Autodesk.Revit.UI.Selection import ISelectionFilter
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import*
clr.AddReference('System.Windows.Forms')
clr.AddReference('System.Drawing')
clr.AddReference('System.Windows.Forms.DataVisualization')
import System.Windows.Forms
import System.Drawing
from System.Drawing import *
from System.Windows.Forms import *
View = doc.ActiveView
naCate = [i.Name for i in doc.Settings.Categories]
fil = "Schedules"
getIndex_Item = naCate.index(fil)
catebyName = UnwrapElement(Revit.Elements.Category.ByName(naCate[getIndex_Item]))
bic = System.Enum.ToObject(BuiltInCategory, catebyName.Id.IntegerValue)
filters = FilteredElementCollector(doc).OfCategory(bic).ToElements()
sche_Name = filters
class MainForm(Form):
	def __init__(self):
		self.InitializeComponent()
	def InitializeComponent(self):
		self._groupBox1 = System.Windows.Forms.GroupBox()
		self._groupBox2 = System.Windows.Forms.GroupBox()
		self._clbNaSchedule = System.Windows.Forms.CheckedListBox()
		self._txtbTotalItems = System.Windows.Forms.TextBox()
		self._cbxAllNone = System.Windows.Forms.CheckBox()
		self._label1 = System.Windows.Forms.Label()
		self._label2 = System.Windows.Forms.Label()
		self._txtbBrowser = System.Windows.Forms.TextBox()
		self._bttBrowser = System.Windows.Forms.Button()
		self._bttExport = System.Windows.Forms.Button()
		self._bttCancel = System.Windows.Forms.Button()
		self._label3 = System.Windows.Forms.Label()
		self._groupBox1.SuspendLayout()
		self._groupBox2.SuspendLayout()
		self.SuspendLayout()
		# groupBox1
		self._groupBox1.Controls.Add(self._label1)
		self._groupBox1.Controls.Add(self._cbxAllNone)
		self._groupBox1.Controls.Add(self._txtbTotalItems)
		self._groupBox1.Controls.Add(self._clbNaSchedule)
		self._groupBox1.Location = System.Drawing.Point(12, 4)
		self._groupBox1.Name = "groupBox1"
		self._groupBox1.Size = System.Drawing.Size(494, 159)
		self._groupBox1.TabIndex = 0
		self._groupBox1.TabStop = False
		self._groupBox1.Text = "Schedules"
		# groupBox2
		self._groupBox2.Controls.Add(self._bttBrowser)
		self._groupBox2.Controls.Add(self._txtbBrowser)
		self._groupBox2.Controls.Add(self._label2)
		self._groupBox2.Location = System.Drawing.Point(12, 167)
		self._groupBox2.Name = "groupBox2"
		self._groupBox2.Size = System.Drawing.Size(494, 57)
		self._groupBox2.TabIndex = 1
		self._groupBox2.TabStop = False
		self._groupBox2.Text = "Export Options"
		# clbNaSchedule
		self._clbNaSchedule.AllowDrop = True
		self._clbNaSchedule.CheckOnClick = True
		self._clbNaSchedule.DisplayMember = "Name"
		self._clbNaSchedule.FormattingEnabled = True
		self._clbNaSchedule.Location = System.Drawing.Point(6, 19)
		self._clbNaSchedule.Name = "clbNaSchedule"
		self._clbNaSchedule.Size = System.Drawing.Size(482, 109)
		self._clbNaSchedule.TabIndex = 0
		self._clbNaSchedule.SelectedIndexChanged += self.ClbNaScheduleSelectedIndexChanged
		for i in sche_Name:
			self._clbNaSchedule.Items.Add(i)
		# txtbTotalItems
		self._txtbTotalItems.Location = System.Drawing.Point(404, 132)
		self._txtbTotalItems.Name = "txtbTotalItems"
		self._txtbTotalItems.Size = System.Drawing.Size(72, 20)
		self._txtbTotalItems.TabIndex = 1
		self._txtbTotalItems.TextChanged += self.TxtbTotalItemsTextChanged
		# cbxAllNone
		self._cbxAllNone.Location = System.Drawing.Point(6, 131)
		self._cbxAllNone.Name = "cbxAllNone"
		self._cbxAllNone.Size = System.Drawing.Size(107, 22)
		self._cbxAllNone.TabIndex = 2
		self._cbxAllNone.Text = "Select All/None"
		self._cbxAllNone.UseVisualStyleBackColor = True
		self._cbxAllNone.CheckedChanged += self.CbxAllNoneCheckedChanged
		# label1
		self._label1.ImageAlign = System.Drawing.ContentAlignment.MiddleLeft
		self._label1.Location = System.Drawing.Point(316, 135)
		self._label1.Name = "label1"
		self._label1.Size = System.Drawing.Size(82, 20)
		self._label1.TabIndex = 3
		self._label1.Text = "Total Items:"
		# label2
		self._label2.Location = System.Drawing.Point(6, 26)
		self._label2.Name = "label2"
		self._label2.Size = System.Drawing.Size(100, 23)
		self._label2.TabIndex = 0
		self._label2.Text = "Output Folder:"
		# txtbBrowser
		self._txtbBrowser.Location = System.Drawing.Point(85, 23)
		self._txtbBrowser.Name = "txtbBrowser"
		self._txtbBrowser.Size = System.Drawing.Size(313, 20)
		self._txtbBrowser.TabIndex = 1
		self._txtbBrowser.TextChanged += self.TxtbBrowserTextChanged
		# bttBrowser
		self._bttBrowser.Location = System.Drawing.Point(413, 21)
		self._bttBrowser.Name = "bttBrowser"
		self._bttBrowser.Size = System.Drawing.Size(75, 23)
		self._bttBrowser.TabIndex = 2
		self._bttBrowser.Text = "Browser"
		self._bttBrowser.UseVisualStyleBackColor = True
		self._bttBrowser.Click += self.BttBrowserClick
		# bttExport
		self._bttExport.Location = System.Drawing.Point(348, 230)
		self._bttExport.Name = "bttExport"
		self._bttExport.Size = System.Drawing.Size(75, 23)
		self._bttExport.TabIndex = 2
		self._bttExport.Text = "Export"
		self._bttExport.UseVisualStyleBackColor = True
		self._bttExport.Click += self.BttExportClick
		# bttCancel
		self._bttCancel.Location = System.Drawing.Point(425, 230)
		self._bttCancel.Name = "bttCancel"
		self._bttCancel.Size = System.Drawing.Size(75, 23)
		self._bttCancel.TabIndex = 3
		self._bttCancel.Text = "Cancel"
		self._bttCancel.UseVisualStyleBackColor = True
		self._bttCancel.Click += self.BttCancelClick
		# label3
		self._label3.Font = System.Drawing.Font("Microsoft Sans Serif", 8.25, System.Drawing.FontStyle.Italic, System.Drawing.GraphicsUnit.Point, 0)
		self._label3.ImageAlign = System.Drawing.ContentAlignment.MiddleLeft
		self._label3.Location = System.Drawing.Point(18, 230)
		self._label3.Name = "label3"
		self._label3.Size = System.Drawing.Size(295, 23)
		self._label3.TabIndex = 4
		self._label3.Text = "Dynamo API"
		# MainForm
		self.BackColor = System.Drawing.SystemColors.ButtonHighlight
		self.ClientSize = System.Drawing.Size(518, 260)
		self.Controls.Add(self._label3)
		self.Controls.Add(self._bttCancel)
		self.Controls.Add(self._bttExport)
		self.Controls.Add(self._groupBox2)
		self.Controls.Add(self._groupBox1)
		self.Name = "MainForm"
		self.ShowIcon = False
		self.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen
		self.Text = "Export Schedules"
		self._groupBox1.ResumeLayout(False)
		self._groupBox1.PerformLayout()
		self._groupBox2.ResumeLayout(False)
		self._groupBox2.PerformLayout()
		self.ResumeLayout(False)
	def ClbNaScheduleSelectedIndexChanged(self, sender, e):
		pass
	def CbxAllNoneCheckedChanged(self, sender, e):
		var =self._clbNaSchedule.Items.Count
		self._txtbTotalItems.Text = str(var)
		rangers = range(var)
		for i in rangers:
			if self._cbxAllNone.Checked == True:
				self._clbNaSchedule.SetItemChecked(i, True)
				self._clbNaSchedule.SetItemChecked(i, False)
		pass
	def TxtbTotalItemsTextChanged(self, sender, e):
		pass
	def TxtbBrowserTextChanged(self, sender, e):
		pass
	def BttBrowserClick(self, sender, e):
		fileDialog = FolderBrowserDialog()
		fileDialog.ShowDialog()
		self._txtbBrowser.Text = fileDialog.SelectedPath
		pass
	def BttCancelClick(self, sender, e):
		self.Close()
		pass
	def BttExportClick(self, sender, e):
		selected = []
		for i in self._clbNaSchedule.CheckedItems:
			selected.append(i)
#____________________________________________________________#
		nameSched = []
		for i in selected:
			nameSched.append(i.Name + ".xls")
		path = self._txtbBrowser.Text
		self.result_list = []
		for index, sched in enumerate(selected):
			schedule = UnwrapElement(sched)
			fileName = nameSched[index]
			try:
				export_options = ViewScheduleExportOptions()
				schedule.Export(path, fileName, export_options)
				self.result_list.append("Schedule Exported")
			except:
				self.result_list.append("Export Failure")
		self.Close()
		pass
f = MainForm()
Application.Run(f)
Looks it be a CPython interop issue. Try IronPython2 as a start. Alternatively I recommend moving to C# and building this as a zero touch node.
Hi @HAQ to use that in CPython3 try just deleting the highlighted line, because I don’t see anywhere the data visualization class is used. it might solve the issue.
there are some bugs with PythonNet 2.5x and Winforms/Wpf event handlers (in Revit 2024.2)
for now, I recommend to use Ironpython (2 or 3) or C# instead
