Structural columns automatic reinforcement using Dynamo
Hello Everyone is there a way for automating Column Reinforcement in Revit ?
for example I want to reinforce this column Manually , then all of the Columns of the same type would have the same reinforcement How can that be achieved ? I would also appreciate a better way if available , I couldn’t find nodes related to reinforcement
Note the reinforcement here are just an example to illustrate the idea
Hi @ahmadkhalaf7892 ,
Why do you want do achieve this through Dynamo, couldn’t you add the needed reinforcement into a type of the family such that every instance you place has the same reinforcement already added?
thank you for your reply , what exactly do you mean by Reinforcing the family ? Can I reniforce coloumn families ?
I am dealing with structural column family , I can’t add rebar in this family .
searching the forums I was able to find these results that might help:
Thanks Mate I checking them now
