Rebar reinforcement similar families(automation )
Is there anyway for reinfocing all similar families in the same way in the project ? By that I mean can I reinforce a circular column (d=300mm for example) in a way , Then all columns of type d=300mm would have the same reinforcement ?
Many thanks
This would help a lot since I am dealing with like 100 column of same type
Why you push that headache to your Revit model ? I think you need to be smart enough to deal with shortage of Revit software in rebar detailing ( heavy files performance - large size files ) and just make a rebar details for only one column as a prototype then deal with count to quantify your rebars.
Thanks a lot man but here he is reinfocing via dynamo , I want to copy the rebars to all columns via dynamo how can that be achieved do you have any idea
QC-Rebar-Copy Columna.dyn (8.9 KB)
I have this script but it is not working any idea what is wrong here ?
Try to connect the out put from (out) in filter mask to last node.
or output of rebar.host direct to last node.
Thanks Man you gave an approach
Working.dyn (14.4 KB)
Just in case someone needed the script in the future
Hello Engineer Ahmad again, This script is working in a good way . But the thing is that when it is copying the rebars it adds also an additional column and copies it , how can I solve this issue
You might use remove duplicate node to avoid duplication of elements.
Thanks Ahmad
