I’m working with Archi-lab_Grimshaw and it seems like “Set Type Parameter” Node isn’t working.
Any ideas of what I might be doing wrong?
Get works fine!
Get works fine!
Are you sure the parameter is a number? and not a string?
I tried both
Is it working fine for you?
Well, I haven’t used @Konrad_K_Sobon nodes for this unfortunately, but I’ve used the Rhythm node SetParameterByName and it works fine.
Thanks!
the archi-lab node is expecting a list if I am not mistaken.
Pretty much what my Rhythm one does.
This node only handles Instance Parameters.
It handles Type Parameters just fine, if you use the Element.Type node, like Einar showed
If “Note d’identification” is the Type Comment Parameter, then it takes a string and not a number. Just FYI
What about set?
I tried this and it works. Great Script Martin_Spence1. Thanks, but I am confused.
Why you select an Element one by one instead o whole Family Type?
In another thread I asked for a node like yours but for change a “Type Comment” of a whole Family Type.
Maybe you know how. Thanks again
Hi, I am having trouble with the same topic, only that I want to set a type parameter which works with intervals. To make it clearer: I have several wall types and I want to set the “Wrapping at inserts” parameter to “Both”, but as it has a drop down for you to choose, when I look for the parameter value, it retrieves a number from 0 to 3 (options are none, interior, exterior, both -something like that) and when I want to set the value to 3 for example, all nodes that I have found don´t accept numbers for intervals as parameter values to set.
Hi All,
There is a Video showing how to set type parameter value into element types.
Dynamo - Set Type Parameter Value into Element Types
Hope it it helpful!
Wow.
Amazing Dynamo script. Just what I was looking for. Thanks
