Set multiple Family Instances by matching List Input for FamilyType
Looking for a way the change an FamilyInstance(list A) by List input(list B).
Stil can’t fix the change instance by input list. I just try all the solution from the others. But sill get an error.
http://dynamobim.org/forums/topic/set-family-type-from-list/
Setting “Family and Type” parameter does not work for you? Could you send a screenshot of your graph showing the error?
Edit: found an example:
Error:
Input for value:
“Type Name” is a read-only parameter, try “Family and Type” instead (optionally “Family” or “Type” if it better fits your needs). The OOTB Element.SetParameterByName node should do this, see the example I provided.
See also:
http://dictionary.dynamobim.com/#/Revit/Elements/Element/Query/Parameters
http://dictionary.dynamobim.com/#/Revit/Elements/Parameter/Query/IsReadOnly
http://dictionary.dynamobim.com/#/Core/Object/Action/Type
I have used Type Name because that’s the parameter that has to be changed.
Also used “Type” But same error.
Also used “Family and Type”
Hi @snnybsch,
If you don’t mind using custom nodes, maybe the nodes below can do what you want.
Kind regards,
Mark
Does not change the families.
Hi @snnybsch,
Have you read the below quote on the topic @Yna_Db sugested.
I think the “FamilyType” input has to be a “real” familytype not a string.
Kind regards,
Mark
You are correct @MJB-online
I was focusing on finding an illustration and did not even pay attention. Next time, I’ll try it myself before refering to anyone else’s solution :sweat_smile:
Actualy the (first) sugested topic was a very good one :thumbsup:
But the most interesting remark was at the very bottom.
Kind regards,
Mark
Other examples:
http://dynamobim.com/forums/topic/changing-loadable-family-types/
Thank you for the concept! I changed it a little bit, but it works!
