This should not be difficult too implement I will do that. Thanks for the feedback it’s very helpful !
Glad it works for you !
Yes there is a way to do that. I guess I can make it an option.
Also a nice update in the future would be to modify the form width/height/text distances etc, without modifying the python script.
@Mostafa_El_Ayoubi firstly, thanks for creating a great package - its helped to shape my UI design and I’m already planning a future release of my package utilising these forms for better Revit Player integration. Naturally all credit will be given!
@thurevit3 vertical scroll is surprisingly a bit of a nuisance, but I happen to be implementing it on a current project:
This is very much WIP as the form I require is going to be heavily customised (tabs, defined size, columns etc), but here’s a snippet of adapted code from the UI.MultipleInputForm++
node which achieves the vertical scroll. Basically, it requires a column to structure the data. Hope it helps, and ultimately finds its way (albeit improved!) in the Data-Shapes package:
for i,j in zip(inputnames,inputtypes):
j.__class__.__name__ == 'listview'
lv = mylistview()
lv.Values = j
lv.CheckBoxes = True
lv.View = vi.List
lv.Sorting = SortOrder.Ascending
[lv.Items.Add(i) for i in j.keys()]
lv.Location = Point(xinput,y)
lv.Width = 360
lv.Height = 200
lv.Scrollable = True
lv.View = vi.Details
form.Controls.Add(lv)
form.output.append(lv)
y+= 230
header = ColumnHeader()
header.Text = "View List"
header.Name = "col1"
header2 = ColumnHeader()
header2.Text = "View Type"
header2.Name = "col2"
lv.Columns.Add(header)
lv.Columns.Add(header2)
header.Width = 160
header2.Width = 160
I had the same issue, thanks for this!!
Hi, I have a question. It is possible to implement your script adding a drop-down menu?
Hi @Tortoise
Please ask your query by creating new thread and link this topic as reference. This topic is already solved. Thanks
