UI.MultipleInputForm++ Windows separate instead of together
Hi, I’m upgrading scripts from 1.3 to 2.3 dynamo in Revit 2020. UI.MultipleInputForm++ is not combing the inputs and bringing up separate windows. Example below.
Dynamo 1.3 Revit 2019 UI.MultipleInputForm++
Dynamo 2.3 Revit 2020 UI.MultipleInputForm++
Then next window will pop up and so on
Graph
@Mostafa_El_Ayoubi
Probably a lacing issue where it’s feeding them in one at a time? Can you screenshot your graph?
EDIT: Also did you upgrade your packages as the jump from 1.X to 2.X was pretty big.
I tried changing the lacing with no luck. Maybe I need to everywhere backwards linking to the UI.MultipleInputForm++? Added graph original post and I upgraded packages.
Can you expand each of the inputs (such as Ui.Listview) that go into the list.create node. If any of those output a list it would cause the error you are experiencing. Your list create node should have an output that looks like
List 0
     0. Input0
     1. Input1
     2. Input2
and not
List 0
     0. List0
                0.Input0
                0.Input1
     1. Input1
     2. Input2
The man. The UI.DropDown Data had a node that needed a flatten. Thank you!
If anyone else needs to see for help
adding the flatten solved it
