Amigos
The mos interesting and usefull of the basics (in my opinion) is to be able to instert Blocks instances, this is included in Dynamo autocad, there are 2 ways to doit, the most simple is when the Blocks exist already in the file!
Block Insert Local.dwg (473.5 KB)
Block Insert Local.dyn (28.5 KB)
Hola de nuevo amigos, another interesting node for autocad is Object.ByGeometry this node allows you to create different objects mainly solids, attention not all objects can be created for example ellipses can not be created you have to be patient the node libraries are still under construction and the community is improving over time!
