I would like to know if its possible to filter out allready deleted shared parameters? Actually, if you delete them manually in revit, you will still find them with with Dynamo, there is a ton of duplicates. Would be nice if I could filter all the “deleted” shared parameters, and remove.
GetDublicatedParameter.dyn (30.3 KB)
Maybe you can modify the graph! i had a similar issue…
KR
Andreas
Hi @Anders_Haugaard try delete permanently a shared parameter using dynamo, not use the manual method. Cheers
Hi @Anders_Haugaard , Ive been playing around with something similar think this should be close.
Hi @Kai looks promissing, To compare GUIDs is really good idea!
I would give it af try. Ill get back soon…
