Delete duplicate parameter except with value
I can find duplicate parameters and delete them but im looking to filter out the parameters that have a value and choose those to keep and delete the rest but i’m stuck. Any help would be appreciated.
Delete parameters.pdf (289.1 KB)
Thanks, Jason
Parameter delete3.dyn (22.4 KB)
Update: I am able to filter out the duplicate parameters and delete the ones without value. The value in the parameters do not duplicate, only the ParameterElement ids duplicate.
Regards, Jason
Hi @Jason_Trahan i am having the same issue now…however the graph is not so clear to see so i cannot re-create the code.
can you share your final dyn file instead?
thanks
instead of copying it, for learning purposes, why don’t you start a new thread, share your own graph and see how far have you reached?
From there we can help you to get where you want.
