Place family from list of coordinates
Hi all,
I’m attempting to get the locations of some elements and then place a family on those points, however I’m stuck on the first half.
Here’s what it looks like at the moment, what’s the correct way to do this?
@Ramsden you can use this solution.
Maybe a duct has no location point, only lines ?
@Johannes_Meiners you can create point or set of points using pointatparamenter node.
like this:
@Johannes_Meiners I think you’re correct about not having points as @rexfrancojesse method didn’t work.
Would I be correct in assuming the ‘0.5’ will give me the center of the curve as the point?
Also could you tell me which package the ‘Element.LocationCurve’ node is from?
@Johannes_Meiners This node seems to have given me some results, is this what I’m looking for?
Can I now use this list of points to insert a family?
0,5 is the T-Value of a curve, like 0.5 of the curve length.
Here the info for the package:
You could also use your ´"Element.Location" and take the curves
Try it !
Almost a success!
The families loaded in but are slightly off.
For clarification, I’m trying to load in a cast-in family acquired from a manufacturers website. The locations of which we have shown as ducts up until this point.
The errors in the Z axis I expected to have to manually correct anyway, due to different length ducts/different thicknesses of slabs throughout.
For some reason they are all 125mm West of the intended position. As they appear to all be wrong I can select all and move them, but it would be nice to know where I went wrong. Do you have any idea?
Look at the family, you place the family by it´s location point to the point you got from the duct lines.
Maybe you can change the origin of the family in the family editor?
That’s probably it, thank you for all your help!
