Hi. I’m interested in placing all types of each family on curve with certain distance.
I was wondering if someone can share the solution here.
How many placement points does your family have?
It’s just a matter of creating a numeric sequence. Based on the number of family types you have, you create that many points along your curve, either with a fixed distance or fixed total length.
Let’s say one. There are host based families and unhosted ones also.
Is there way to count number of family types by dynamo? Because some families have FT catalog with several types in there.
Sure. You would have to have a list of all your types in order to place them, so you could easily get a count of that list.
It work with placing all types of choosen category.
But it place all elemenst from same choosen category in one column. It will be greate to have each family types in different column. Is it real?
Definitely. What you need then is the count for total types in each family and the count for total families. Then you can create a points list for each type based on the family (X coordinate value) and the type (Y coordinate value). Just make sure your list structure is a list of families with sublists of each type and you should be a good shape.
That works for one placement point Categories
How about “more” placement point Elements like Floors?
The x- and y-coordinates based on families and types is more of an “origin point” for defining placement arrays. For typical “point-and-place” families that’s all you need. For line-based or boundary-based objects you’d obviously need to define those geometries separately, but they could still be based off of the singular x- and y-coordinates determined by the above process.
For now I need to place loadable families, so hard shaped/sketch/adaptive/etc families we can ignore. Thanks you for your attention.
Thanks for playing along Nicky, now this man knows what to do
Find the close curve node
Thank you all. I’m going to test it. After positive output I’ll share method/screenshot. Probably someone else will meet same problem in future.
BTW it’s time to add visual library views in Revit. Which will allow users to create schedule based on library element to compare parameter values and determinate missing values.
What if someone downloaded a Family that helps him/her out of time-issues, lets say an architect.
