I’m having trouble moving sections bij a given vector. I’m making a script that duplicates a selected sectionview from a floor plan, and I’d like to move it as well by a given vector. This however gives every time Errors.. Anyone that can help?
Nico
Hello @fernandezP7VN2 and welcome to the forum
not 100 what you want exackly, can you show your graph, what you have tried so far ? one way maybe but not sure if it is you are after or more move the crop view maybe
Yes this is what I want, but to then move the section in perpendicular direction. The problem I’m having still is that I don’t have the SOVI nodes, so I don’t know how to get the section line locations.
which revit version are in, if in 24 and guess 25 as well you can get location from genius loci get location node…but in 26 i dont think it works
but we can get the location with the view itself, with get the far clip offset handles as should be in center…thats how my dirty method works
Hmm okay. Essentially what I’m trying to do is to select a grid in Dynamo (lets say A) and get the corresponding sectionview with the name A. I also have a selection of other grids that are parallel to grid A and I want to duplicate view A, rename them to the corresponding grid they are going to and also move them in that direction with the corresponding distance.
Do you follow?
no not really, can you show your graph so far, and could probably bring light to my small brain
So what I want is to select grid A and also select all other grids that are parallel. I then want the section with the same name as the grid to duplicate, move to one of the other grids and be named the same as the grid it is going to
thanks but try zoom in the image How to export a graph image [Correctly] and share your python script…anyway how then just create a section and give it that name…
Yeah I know, but having this I could use it in any project I start, and I won’t be needing to rename it every time and give it the right View Template.
and Python node is:
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import \*
refGrid = UnwrapElement(IN\[0\])
grids = UnwrapElement(IN\[1\])
if isinstance(refGrid, list):
refGrid = refGrid\[0\]
# Referentie
refCurve = refGrid.Curve
refPt = refCurve.Evaluate(0.5, True)
gridDir = refCurve.Direction.Normalize()
# Loodrechte richting in XY
normalDir = XYZ(-gridDir.Y, gridDir.X, 0).Normalize()
# Bepaal dominante as (X of Y systeem)
absX = abs(gridDir.X)
absY = abs(gridDir.Y)
if absX > absY:
dominantAxis = "X-aligned grids -> offsets in Y"
axisMode = "Y"
dominantAxis = "Y-aligned grids -> offsets in X"
axisMode = "X"
# Outputs
names = \[\]
signedDistancesMM = \[\]
vectorsMM = \[\]
axisType = \[\]
for g in grids:
pt = g.Curve.Evaluate(0.5, True)
vec = pt.Subtract(refPt)
# signed distance (loodrecht op grid A)
signedDistanceFt = vec.DotProduct(normalDir)
signedDistanceMM = signedDistanceFt \* 304.8
# vector mm
vecMM = XYZ(
vec.X \* 304.8,
vec.Y \* 304.8,
vec.Z \* 304.8
# bepaal of beweging X of Y dominant is
if axisMode == "X":
axis = "X"
axis = "Y"
names.append(g.Name)
signedDistancesMM.append(round(signedDistanceMM, 1))
vectorsMM.append(vecMM)
axisType.append(axis)
OUT = names, signedDistancesMM, vectorsMM, axisType, dominantAxis
Hi @fernandezP7VN2 probably me, but couldnt just create the sections work then
