Section Box by Level with new view and NWC export
dynamo
revit
#1
I can get the script to section the model correctly using the section by elements. but i cant get it to Duplicate the 3d view without showing the stuff above the sectionbox
1.) Before Section
2.) After Section; {3D} View
3.) After Section; In Newly Created View
4.) Section box is in right spot it just doesnt section.
HERE IS GRAPH:
HERE IS DYN AND REVIT FAMILY:
Section Box from origin.dyn (51.1 KB)
Section Box Family.rfa (328 KB)
Modify outside of transaction ERROR
#2
Duplicating the view with the correct section box is the most important thing. i have another script that can export all the views.
#3
Does manually modifying the section box (ie: lower the top extents) after the fact fix the issue?
#4
@JacobSmall yes or moving it in anyway. I tried to move the section box in dynamo, but was unsuccessfu. i need it to move and then move back to the original location.
#5
In that case, try adding a chunk of script similar to the other post to move the section box - 1/32" on the Z axis and see if that resolves this issue as well.
#6
@JacobSmall Could you post the python script here so i dont have to retype it?
#7
Haven’t used preformatted text yet, but here goes nothing:
clr.AddReference('RevitAPI')
items = {UnwrapElement(IN[0])}
xyz = UnwrapElement(IN[1]).ToXyz()
ids = list()
for item in items:
	ids.append(item.Id)
itemlist = List[ElementId](ids)
moveditems = ElementTransformUtils.MoveElements(doc,itemlist,xyz)
OUT = items
#8
how do i get an element from the duplicated view
#9
@JacobSmall im getting an error
#10
I was able to find a solution by creating my view before sectioning instead of after. thank you
#11
Great news and glad to help!
Can you do me a solid and upload a screenshot of the completed script so others can refer to it if they have the same problem?
#12
