How to export a graph image [Correctly]
Hello All!
While i agree 110% with Dimitar Venkov on his “How to get help on the dynamo forums” i want to expand futher on his point 4 as it appears to me to be a recurring theme to get adequate image exports from Dynamo.
How to Get Help On The Dynamo Forums - Point 4
Step 1
Run the graph, with any errors you are encountering.
Step 2
Expand the Data Nodes on the whole graph or on a troubled section you are requesting help with using the Pin button. Ensure that if you are doing this everywhere, that you do not obstruct the visibility of the wires correcting nodes, remember that nodes before and after the errored node as important as the node itself.
Step 3
Zoom into the graph as far as you can go (It doesn’t matter if this is white space)
Step 4
Press the “Export as Image” button on the top right hand side of the Dynamo Application and select
The “Workspace” option, note that on older versions of Revit this may be shown as a camera icon.
Step 5
Save the Image somewhere accesible. (ie: Desktop)
Step 6
Drag the image into the post creation window on the dynamo forums where you are writing your text dialouge. (Be patient and ensure the image is showing in the preview window before you post)
Your uploaded image should be of this example quality to ensure others have a chance of reading what you are trying to ask.
I want import to revit but It is not I want
Applying view templates twice to same view in 1 script
Help simplify model
BimorphNodes Elements.Intersect assigns the same room name/number to all elements
Auto dimension to centre of column to closest grid
Space Number in elements From Spaces in external link
Geometry.DistanceTo_AS
Wanted to place section views parallel to walls, but I am creating it perpendicular to the wall
Optimizing 3D Polyline Geometry Extraction Workflow
Home configurator with groups and globalparameters ( issue )
Line up the text that comes after dimension number?
Shaded
Parameter.Group note replacement
Multiple error in nodes
Creating a shared parameter list from an Excel file and dynamo
Dynamo model and Revit Model → reverse direction?
Family edit
Element to a determinade point ( that i click ), but its not working
How to Convert Cuboid to Element in Revit?
Make Dynamo read Dots out of "Dummy" Schedule
List levels not working anymore?
Enable connection visibility when the conduit closest to it is identified
Draw lines based on the elevational differences between two cogo points
Filter line top bottom side
Spring nodes doesnt work in Revit 2024
I want to create script to create views for assembly and i don't know what is the problem in this script
Accessibility through doors
Place a family along a line
Creating and Renaming Worksets without Packages
Flex pipe
Package version unknown, help please!
Automate Creation of Models
Need Help Coloring Elements by Material GWP – Getting Errors in Script
Make the normal vectors of multiple polylines constant
How can I make the script copy the ceiling for several levels at once, and when I add a level, for example, can I edit the script and add a level, and it will add a copy of the ceiling to it?
Column from cad to revit
Section View to Drafting View
Room Finish Boundry Join Curves
Help with Automated Quality Check Script – Getting Empty List and Blank Excel
How to move all objects of one type, on one layer to a new layer
I'm trying to fix lines drawn off axis whats wrong
Property set (Corridor Shape Information)
Pipe and Pipe Fittings Insulation by Size
Question about Form.ByLoftCrossSections
My Revit model is not showing in Dynamo and the scripts don't work
Automatic placing cable tray support node FamilyInstance.ByCurve return null
Elements in Site Category
How to correctly join multiple curves to create a ceiling in Dynamo?
Group parameter "Allowed View Types" accessible
2 lines after line segmentation with Dynamo
Nice work!
For beginners the “troubled section” often is the error inducing node only.
I’d suggest to stay with the instruction to ‘open all node results’, or get a little more in detail to point out that the nodes before an error are as important as the error message/node itself.
This will be the second most reposted thread ever :wink:
Step 4 is the big one.
Also no photos of the PC screen ideally…
