First of all , I apologize for my English
I’m new dynamo , but I’m very surprised at everything he does .
After reading many topic , I am trying to create my own scripts.
I have a problem because I need to get sections from the grids.
Insert the image.
I’ll be doing something wrong.
Once successful , I would like to include an offset to these sections from the grids.
Thank you
Here is a graph that creates section views along each grid axis and sets the depth to +/- 750mm:
makeSectionsAtAxis.dyn (41.3 KB)
Perfect.
It works perfectly.
Thank you, very much
@Einar_Raknes , Do you think it would be possible to limit the sections along the numeric grid lines to just two alphas. I.e. along grid 1, from A-B, then B-C etc.
I am trying to create 3d views of each grid bay, I figure once I have a section that matches the grid I can apply it to a 3D view.
Your obviously talented at this, Would appreciate your thoughts. I am a newb to dynamo. I know what I want it to do, its the getting there thats the hard part. I am finding the best way to learn is to modify the stuff of others first so I learn what the blocks all do. Yours is just way over my head at the moment
@Einar_Raknes I am getting an odd error message in Revit 2026 that I am having trouble understanding. The last node of the script does not show any view names for the sections it is supposed to create and in Revit I am seeing an error message about duplicate view names. I cannot quite figure out what is going on and was hoping you might be able to shed some light on the issue for me. Thanks!
This was a post from 2018.
You have work to do
