Hi, could someone please show me how to get the curve of a section line so I can move the section?
there is this post but I cant see it and thought there might be a way now?
I don’t think is possible there are no Properties in the API for getting location line of sections. Also there are no methods for setting a section view location exposed in the Revit API.
https://www.revitapidocs.com/2020/0d37c868-8b5e-3ebd-d037-15b3c993f0d6.htm?section=methodTableToggle
Edit: Perhaps you can create a new view in the location you want a delete the old one automatically in a Dynamo script. This is kinda tricky though.
have I approached this all wrong because the view bounding box dosn’t relate to the plan view?
Well this works. Why, I dont know. its slightly off on the location but Ill figure out why in time. If anyone ends up interested in this.
There he is! The master at it. Thanks so much! I’m gonna loose my job if I dont get back to normal work soon
but looking forward to giving this a go! Will be so much easier. Ill get to keep the views templates and things that it copys through with too
Is the node trying to move the view in the Active view still or is it a bit lost? Try removing the section of python that defines what happens if the code is successful, and put the ElementTransforUtils command in the ‘top’ level of code. Then you can see what errors occur.
If still an issue, I am in the office this afternoon and will post an example.
It moved the section. Just somewhere crazy I cant find it I think
Hmm sounds like a co-ordinate system issue then. What happens if you remove the transforms?
Should be an easy tweak
epp for me or you
I’ve dabbled in trying to get python to take lists before with no luck
