Hi, key scheduling …my favourite aspect of Dynamo/Revit
I have attached a definition, simple excel array with a screen capture showing the columns in a surprising order.
They should be in A,B,C…
Can anyone identify the reason for this?
I have another question: can I generate the project parameters in Dynamo ie Column A,B C…rather than creating them in Revit under project parameters required to push the excel data to Revit.Concrete Mix_Basic_Array.xlsx (13.4 KB) Concrete_mix_table.dyn (32.0 KB)
To coin a classic expression: “Just when you thought it was safe enough to go back into the water…”
Here’s how you can create project parameters from Dynamo:
Unfortunately the image of your graph is too far zoomed out and illegible. The parameters (columns) should show up in the order you specify. You’ll have to post another image so we can better see what’s going on.
Ah. Because you’re doing each parameter separately there’s a chance Dynamo could run them out of order. Instead of feeding the ViewSchedule input from the original selection to each Key Schedule node, try stringing the output from A to the input to B and so on.
Thought that your idea would solve it…it didn’t but sent me in the right direction
Revised the dynamo def, didn’t seem to have any list issues revised definition
attached. Concrete_mix_table_simplified.dyn (28.9 KB)
I do think there was an issue with Revit when I set up the project parameters manually by creating Columns A…D in Revit. I have a very basic grasp of Revit. I’m trying to set those in Dynamo following your previous threads.
What seemed to solve it was too close down and restart, although it took a couple of attempts dynamo and Revit.
Brought my notebook home…it was driving me mad.
There seems to be an issue when the Key Name parameter is used once that’s removed Revit the order seems to be as expected.
Glad you got it worked out. It’s always a good idea to close Dynamo (and even Revit sometimes) and try to run a new definition from a brand new session. Sometimes the cached data gets mixed up when running graphs as you build them.
