Exporting Panel Schedules to Revit
We are preparing the Electrical Panel Schedule in Revit. Is there a way to export those schedules to excel using dynamo and make modification then bring it back?
Best Regards,
Abdullah
Dear Eric,
Apologies.
Thank you very much for reminding me of the guidelines.I will try to follow it as much as i can.
Best Regards,
Abdullah
hello, Did you find any solution yet ?
This particular topic of Revit to Excel and then back to Revit has been covered a lot in post here and elsewhere. I reccomend that you try something out and post back if you get stuck.
@jacob.small I’m not sure if it has as Panel Schedules are not component schedules, and have their own methods that differ from ViewSchedule’s. I’ve only recently implemented Panel Schedule support to BimorphNodes Schedule.GetData node (in V2,1).
@Ahmed.Elmahdy if that is what you are referring to, then it is possible to export Panel Schedules to Excel, however you will need to code it yourself or wait until BimorphNodes v2.1 is released to do it. There are methods in the API to write data to Panel Schedules, but as far as I’m aware, this functionality has not been exposed in any package so you would need to code this yourself. There are other complications as well, since Panel Schedules comprise a Header, Body and Footer, all of which can accept values, but the cells are automatically merged resulting in differing numbers of cells per row and this which makes writing data to a from Excel more complex.
Thanks @Thomas_Mahon I’ve searched before and i know if there is a way to do that it will be very difficult because panel schedules is more complicated than quantity schedules.
Don’t hesitate to show what you tried and add all relevant links, it will make it easier for everybody to get the point of this issue
I managed to get a way to export all the panel schedules to excel using dynamo. I found the steps from the following link
I was trying only with element schedules it worked. Then one of my colleague was pushing me to check for Panel schedules, i was hesitant to try. Then, with the same script i changed the category and it worked.
Here is my script for the Panel Schedules.
ALM_ExportPanelSchedulesToExcel.dyn (19.1 KB)
Thank you Thomas. I was able to export it. There are few data which gets missed. Please refer the snapshots.
Best Regards,
Abdullah
@ashanmugam I cant replicate this problem. Have you refreshed your data? If so and it still doesn’t show, upload a simple example file which can be tested.
The file is here.
Best Regards,
Abdullah
@ashanmugam thanks for the sample file. Unfortunately this looks like a bug in the Revit API as the schedule footer is incorrectly reporting only 4 cells (2 rows and 2 columns) when there are clearly more than that. I’ve attempted to index the cells beyond these numbers, but unsurprisingly, it fails.
In testing before v2.1 release, I did notice other anomalies when accessing data from an Electric Panel Schedule, such as indexing failures even when the reported rows and columns indicated they were within range, so I decided to bypass these problem area’s and it seemed to be acceptable when checking if there was any loss of data (for the most part, there wasn’t any). The only option is to get Autodesk support to investigate and confirm the cause as there appears to be no solution through the API.
please could you provide me with any guide how did you create this panel schedule template in revit ? at least adding RCCB sections
Thanks Thomas, i was able to export my schedule into excel even though there are still some items that are missing but its all good but after my 2nd try of exporting the excel file is empty and dynamo is showing some errors/warnings. any idea how to fixed this?
thanks
I am trying to use this script, i am missing two node as below,
UI.Filepath Data
UI. Listview Data
May i know from which package i can get this nodes, or if possible can you share these nodes.
Thank you in advance.
Update Datashapes to the latest version.
Hi @jacob.small this is my first post here and a rookie in Dynamo still :grinning:. Trying to run this script on Revit 2019 to export a Panel Schedule to Excel and have the Data-shapes updated (maybe too updated 2021.2.91) and Bimorphnodes 3.0.3 and getting the same error as m.mollena what am I missing?
Please post more info showing the issue - what node is failing and how - otherwise we are just guessing at the issue.
Here it is:
they are exactly the same as the m.mollena
Looks like you have to replace the datashapes UI++ node, and or install the package. If there are additional Red nodes to the left those would have the same issue.
