Looking for a script to export panel schedules from Revit to Excel
Any help would be appreciated!
Thanks so much
Thanks so much
@j.thomas I do have the script but the output in Excel does not look the same as in Revit the way the panel schedules look.
thats okay! Thank you!
@j.thomas do you know if there are nodes in Dynamo which could make the graphic appearance of the nodes look the same as a panel schedule in Revit?
no I do not. you said that you have the script?
yes I do have the script… I am looking for node recommendations for it to appear graphically the same way they would appear in Revit.
Im looking for just the script. I have no idea about how to make it the same i assume it is impossible.
professional third party apps that transfer data cant even do it
would you be able to share your script?
