Please give me the idea for create rail by defined rail section and the inclination will be maintain the cant angle.
Available inputs: 1. Two Rail Tracks as 3d poly Lines/as feature Lines.
2. Rail Cross Section
hi
Can you attached example drawing
Hi
Yes, as @hosneyalaa say, what have you done so far?
Please read this post as well How to get help on the Dynamo forums - FAQ - Dynamo (dynamobim.com)
Hi Please find the bellow Google Drive Link for Drawing file and Dyn file:Dynamo Rail Placing - Google Drive
Hi @patrick.ericson
Thanks a lot for your valuable time!
Can You please redownload the drawing file from the same link.
There will be available the feature lines just below of the 3d Polylines.
Actually, I have tried by two methods i.e. 3d polyline and feature line.
Buenas amigo @haripada.jana como estas?
Disclamer: The correct way to do this is to create Assemblys or Subassemblys directly in C3D, the example I am going to share with you is only for didactic purposes.
The alternative is to create a solid by loft, the idea is to create coordinate systems along a curve and give them the proper rotation to each CS then simply place the profile on each CS and create the solid, it would be interesting to create a roller coaster.
Good point, I agree on that. It will also be better to use the cant from alignment and push it into the corridor
Hi
Try this . I am think it is good
