Featureline Cant and dynamo expression
Hello everybody I need some assistance in some major problem. The script that I made it will put some block in a corridor using a feature line, but I bet that everyone of you knows how to do it. The problem that I have is following, when I put a tie rail as a block it will put following a feature line but it wll not put that block when a fetureline has Cant, that because I did not find an expression that will help me doing so
So, this picture will be with dynamo script
Please anyone could help in this matter?
The same problem I have when I put some NewJerssey parapet in ax road and in some cases it wil put it in stairs, and that is not ok!
Thank you all
Hi @mircea.nicolauLEH2A,
Can you take a look at this thread and see if it helps you?
Yes, that is it for rail!
Many thanks Jensen!!!
