I everyone, i am newbie to use Dynamo, I have a question: it’s possible to extract Civil 3D feature line, to Revit, for after build, for example, a generic wall?
Thanks to all!
A search of the forum gave me some results:
Yep Revit does not work well with these. So the perfect idealistic solution for me would be approximating these while extracting the data from the XML. I guess Civil Structures does something similar, but I don’t really know.
I guess if it has the equations for these internally it could trace them with different values to get some coordinates but this is only my theory
In my opinion, it’s difficult to vision Dynamo being implemented into Civil 3D from a programming standpoint. I definitely agree that the Subasembly Composer or the corridor property window leaves a bit to be desired and Dynamo can definitely fill that void. Autodesk has taken Dynamo and made it into its own separate software package called Dynamo Studio so I can potentially see some creative uses of that with their existing product lines. Also, there’s no mention that Dynamo Studio was solely b…
Hi All,
Can I get Dynamo Script to create Topography from CSV file which are from Civil 3d
