Auto-Dimension from Walls
Hi All,
Just a WIP incase anyone has a free Sunday and fancies a play with it! Otherwise I’ll get back on it on Monday…
Following the amazing work here:
I want a graph which will create individual dimensions (so I can check them against brick dimensions) and automatically create the dimension location lines.
So far I’ve got here… It’s nearly there, but rather than create a dim per ‘reference’ it’s creating a dim per line… It’s also doing something weird with the view… The created dims are in Revit but not appearing until I change their type.
Any assistance appreciated!
Cheers,
Mark
auto dim walls-14.dyn (38.9 KB)
clr.AddReference('RevitAPI')
#create a for loop to go through every index
b = IN[0]
elements = IN[1]
dim = 0
a = []
for x in range (0, len(b)):
	line = UnwrapElement(b[x]).GeometryCurve
	elementsRef = ReferenceArray()
	opt = Options()
	opt.ComputeReferences = True
	opt.IncludeNonVisibleObjects = True
	opt.View = doc.ActiveView
	for element in elements:
		elementsRef.Append(element)
	dim = doc.Create.NewDimension(doc.ActiveView, line, elementsRef).ToDSType(True)
	d = dim
	a.extend ([d])
	OUT = a
Minor update, the springs.list.subpairs node is awesome!
So this is where I’m leaving it for the moment… putting the python in a custom node let me work at level 2, so if I Pick a wall I get all the dimensions along it offset automatically.
If I get more time I’ll keep working on it…
Any assistance welcome!
Mark
DimWallsAuto-Chop.dyn (46.8 KB)
Dim.FromReference.dyf (5.1 KB)
Just an update, I’ve got it working for multiple walls in active view and removed the need for a custom node by updating my python.
Thanks to all who’s work I have built upon,
Mark
It struggles with angled corners as you’d need a reference ‘point’ rather than plane, any suggestions welcome :slight_smile:
EDIT: It’s also using the angle of the wall to work out which should be dim’d, so I’d need to get only the wall faces which are vertical and not aligned to the location line, then pick the point closest to the location line which intersected the external face… simples… Getting the ‘point’ might be the easy bit!
DimWallsAuto-All.dyn (64.7 KB)
It is just an Idea that I haven’t tested. Can’t you take start and end of the wall as references?
Hi :slight_smile:
Thanks for the response!
So… My dimension wouldn’t want to be from the End Point of the location line… Otherwise it would be too short…
Unfortunately the relationship between references and geometry seems very easily broken, I would need an actual point on the wall corner somehow…
I could make a dimension to a reference plane, but it wouldn’t be dynamic, or I could extract a corner point from the geometry of the wall, but it then loses it’s association.
Thanks again,
Mark
What packages are needed to make this work?
Maybe it’s much easier to be done in Python itself.
from Autodesk.Revit.UI.Selection import ObjectType
def isParallel(v1, v2):
#it needs two vector
return v1.CrossProduct(v2).IsAlmostEqualTo(XYZ(0, 0, 0))
ref = uidoc.Selection.PickObject(ObjectType.Element)
wall = doc.GetElement(ref)
ln = wall.Location.Curve
wallRefArray = ReferenceArray()
opts = Options()
opts.ComputeReferences = True
opts.IncludeNonVisibleObjects = True
opts.View = doc.ActiveView
for obj in wall.get_Geometry(opts):
if isinstance(obj, Solid):
for face in obj.Faces:
if isParallel(face.FaceNormal, ln.GetEndPoint(1) - ln.GetEndPoint(0)):
wallRefArray.Append(face.Reference)
t = Transaction(doc)
t.Start(“Create Dimensioning”)
doc.Create.NewDimension(doc.ActiveView, ln, wallRefArray)
t.Commit()
the above code works in PRS, however with minor changes can run in Dynamo
Hi @Dave_Vaughn just the usual I think… Clockwork? Since this was done, Genius Loci has added quite a view nodes for references…
Hi @Sam_Dehghani, thanks for your code, it’s very interesting :slight_smile:
Here’s my version to run in Dynamo… You need to add more libraries & I would recommend using the transaction manager. I had updated mine in the first post to give the working version. If you use the </> button when you paste it will be formatted.
# Import RevitAPI
clr.AddReference("RevitAPI")
import System
# Import Element wrapper extension methods
opts = Options()
OUT = doc.Create.NewDimension(doc.ActiveView, ln, wallRefArray)
My graph is doing quite a few more things than your code, when all that’s in, your code will be a bit more complex.
It would also be great to find a solution to the walls which are not perpendicular :slight_smile:
It requires isolating edges of the External face which are vertical, then finding those which intersect surfaces which are not perpendicular or aligned to the external face… My python isn’t that good yet :slight_smile:
I updated my graph to run off the external face, otherwise, as you see on the below image, you don’t dimension the intersecting walls.
Cheers,
Mark
Hi Mark,
I’m glad that the Python code helped. It’s not that difficult to prepare a code to make dimension between interior walls, however combining the exterior and interior is a bit complex
Hey, it’s not too bad if you isolate the exterior face (the surface with the same vector as the wall.Orientation) then you can run intersection checks against it and the surfaces which are perpendicular to it… At least if you’re just getting 1 dimension, you’re not bothered what order the references are in :slight_smile: It’s a bit more fiddly if you want to pair them up and make individual dimensions, though quite doable.
So, some success… I’ve tried running it off Edge references rather than Face references, it occured to me that the ‘Point’ you get in Revit is actually a vertical edge…
It works at least, though you have to make sure your wall joins are mitred.
Also, on the other side, Revit thinks of the external ‘edge’ as stopping before the joint of the wall… So I need to get the adjacent wall face as well.
Also I need to find a way to prune duplicate references from my list.
i mport clr
# Import RevitAPI
import System
def isAlmostEqualTo(v1, v2):
    return v1.IsAlmostEqualTo(v2)
opts = Options()
frontFaceEdges = []
edgesObj = []
             #if face is normal is equal to wall normal it is the external face
            if isAlmostEqualTo(wall.Orientation, face.ComputeNormal(UV(0.5,0.5))):
                frontFace = face
                for edgeL in face.EdgeLoops:
                    frontFaceEdges.append(edgeL)
        #we want edges which intersect the external face
        for edgeO in obj.Edges:
            if frontFace.Intersect(edgeO.AsCurve()):
                edgesObj.append(edgeO)
vertEdges = ReferenceArray()
#get edges in faceEdges which are vertical up
for edgeF in edgesObj:
    #if edge is up, get it
    if edgeF.AsCurve().Direction.Normalize().IsAlmostEqualTo(XYZ(0,0,1)):
        vertEdges.Append(edgeF.Reference)
#vertFaceEdges = ReferenceArray()
#get edges in front faces which are vertical up
#there are multiple loops if we have hosted objects, we want the first
for edgeFFE in frontFaceEdges[0]:
    #if edge is down, get it
    if edgeFFE.AsCurve().Direction.Normalize().IsAlmostEqualTo(XYZ(0,0,-1)):
        vertEdges.Append(edgeFFE.Reference)
OUT = doc.Create.NewDimension(doc.ActiveView, ln, vertEdges)
Hope that’s of interest, any comments welcome :slight_smile:
Mark
Hi Mark,
The following code may somehow do what you asked for.
Please give me a shout out if it was the one.
#@Suncobim.ir, Email:info@suncobim.ir
#Author: Sam Dehghani
def isPerpendicular(v1, v2):
if v1.DotProduct(v2)== 0:
return True
return False
intersectedWalls =
ref = uidoc.Selection.PickObject(ObjectType.Element, “Select a Wall”)
dimLn = doc.GetElement(ref).GeometryCurve
collectedWalls = FilteredElementCollector(doc, doc.ActiveView.Id).OfClass(Wall).ToElements()
for collectedWall in collectedWalls:
if dimLn.Intersect(collectedWall.Location.Curve) == SetComparisonResult.Overlap
and isParallel(dimLn.Direction, collectedWall.Orientation):
intersectedWalls.append(collectedWall)
opts = Options()
for intersectedWall in intersectedWalls:
wallRefArray.Append((HostObjectUtils.GetSideFaces(intersectedWall, ShellLayerType.Exterior))[0])
wallRefArray.Append((HostObjectUtils.GetSideFaces(intersectedWall, ShellLayerType.Interior))[0])
t.Start(“Dimension”)
doc.Create.NewDimension(doc.ActiveView, dimLn, wallRefArray)
t.Commit()
Very cute, I didn’t know about the HostObjectUtils :slight_smile:
Here’s my version, still needs some tidying…
# Import RevitAPI
import System
# Import ToProtoType, ToRevitType geometry conversion extension methods
clr.AddReference("ProtoGeometry")
from Autodesk.DesignScript import Geometry as geom
        return True
        return False
ref = uidoc.Selection.PickObject(ObjectType.Element, 'Select A Wall')
wallCrv = ln.ToProtoType()
wallNormalExterior = wall.Orientation.ToVector()
offDist = IN[0]
offCrv = geom.Line.Translate(wallCrv, wallNormalExterior, offDist)
intersectedWalls = []
    if ln.Intersect(collectedWall.Location.Curve) == SetComparisonResult.Overlap and isParallel(ln.Direction, collectedWall.Orientation):
opts = Options()
frontFaceEdges = []
edgesObj = []
                frontFace = face
    #get external side faces of intersecting walls
    vertEdges.Append((HostObjectUtils.GetSideFaces(intersectedWall, ShellLayerType.Exterior))[0])
    #thanks Sam!
    #get internal side faces of intersecting walls
#    vertEdges.Append((HostObjectUtils.GetSideFaces(intersectedWall, ShellLayerType.Interior))[0])
OUT = doc.Create.NewDimension(doc.ActiveView, offCrv.ToRevitType(), vertEdges)
HostObjectUtils helps a lot
I downloaded the Clockwork package, but I still get the error: Custom node definition is not loaded!
I installed the latest clockwork that matches my dynamo, or should I have an earlier version?
Hey,
Maybe, which node/s? there is a depreciated page on Andreas’ github?
These are the nodes I get the error on:
  • Get Revit ActiveView
  • Elements in view by category
  • Wall.GetWallType
  • WallLocationLine.FinishFaceExterior
  • Surface.FilterByOrientation-Clockwork
  • Wall.ByFace
  • DanEDU.List.Clean
  • Element.Delete
I’m using dynamo 2.0.3 and I’m using the clockwork 2.x
I installed all older versions for Clockwork, now I only get the error for:
  • Wall.GetWallType
  • DanEDU.List.Clean
  • Element.Delete
    (2 lesser then previously)
Hey,
So maybe try just typing in the name and seeing if it’s an update issue? I think Wall.ByFace is a Revit one…
DanEDU was replaced by Orchid, if you have that package? I think Element delete might be in there? But there are equivalents in Archilab and others…
