Hi all,
I posted this question some time ago, and I simply cannot figure out what I need to do to get this to work the first time. There are extremely strange situations where it will work (Like closing the Revit file, changing the list level of the Parameter.GetValue node, then rerunning), but permanently changing the list level to the one that worked does not solve the issue.
What I am trying to do is extract a whole bunch of parameter information from several closed family document files, by background opening them and writing the info to excel.
I am really out of ideas, if someone could help me with this I would really appreciate that. The only thing that is not exporting are the actual Parameter values, everything else exports fine.
I have attached the DYN file in the hopes that it will be helpful.
Thank you.Family Parameters Data Extraction 2.dyn (126.6 KB)
