Removing parameters in document (Orchid)
So i’m trying to open a family document, remove some parameters and then close and save the document. For some reason parameters are only being removed from 1 document instead of 2 and the file is not saving (because the remove parameter node is getting null for some reason)
Can someone help me fix my script ?
Here are the two families and the .dyn file i used.
_PIA_UN_Pomp_CB_BMG_test - kopie.rfa (2.2 MB)
_PIA_UN_Pomp_CB_BMG_test.rfa (2.2 MB)
SimpleTest.dyn (15.8 KB)
Thank you for the quick reaction and the package update!
You have your hands full making nodes we use. So I understand that u cannot always test every node on every issue. I use a lot of the nodes so I’m glad I could be of a little help.
Alternative solution to Orchid package nodes
https://www.linkedin.com/pulse/delete-duplicated-project-parameters-revit-dynamo-romero-vivancos/?published=t
