I’m looking to extract all of the parameteres (names) from all our families to an excel spreadsheet.
I’m using a python script (which I’m still learning) in the process but I can’t seem to resolve an error when dealing with more than one file.
Any help would be appreciated.
You need to make “PL” a list by declaring it above the for loop pl = and use pl.Append(iDoc.FamilyManager.Parameters). Right now your just getting the last one as an output.
You need to assign “pl” to the OUT variable, not the lowercase out that you have. (Note I had to use paths, but I modified the code to work with your script before posting.)
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import FamilyManager
app = uiapp.Application
docs = IN[0]
pl = []
for iDoc in docs:
pl.append(iDoc.FamilyManager.Parameters)
OUT = pl
One thing to keep in mind is that if you only feed this node 1 family, it is going to break.
