What happened to Dynamo Today?
Anybody know if any back end changes happened to Dynamo today?
No system changes on my side but halfway through today Dynamo became UN-Usable. 10-15 minutes for any and every action. Nothing I tried made any difference, until eventually on one of my restarts, Revit asked me to re-sign in, and I had to agree to new terms and conditions. After that, it is lightning fast. Load times for my graphs feel way faster than usual.
Just sayin… this feels really odd.
Was this Dynamo for Revit or sandbox?
If Revit, check the journal from that session for odd lines, and the Dynamo log as well.
Hey Jacob,
Honestly, I’m not really sure. Doesn’t appear to be any odd messages in the journal:
In this journal example you can see Dynamo being launched from the ribbon at around 2.49 pm, and then I finally decided to give up and kill Revit at around 3.47 pm after achieving nothing. That was me trying to open a graph, but never made it as far as getting the workspace able to place a node, each step in the sequence took ages between allowing me to click anything
 Jrn.MouseMove    0 ,   1117 ,    705
  'E 08-Sep-2023 14:49:57.564;   0:<
  Jrn.RibbonEvent "TabActivated:Manage"
  ' 0:< ::76:: Delta VM: Avail -37 -> 134176933 MB, Used +13 -> 1525 MB, Peak +10 -> 1526 MB; RAM: Avail -13 -> 18127 MB, Used +14 -> 1510 MB
  ' 0:< GUI Resource Usage GDI: Avail 9047, Used 953, User: Used 446
  'E 08-Sep-2023 14:49:58.792;   0:<
  Jrn.Command "Ribbon"  , "Launch Dynamo , ID_VISUAL_PROGRAMMING_DYNAMO"
  ' 1:< ::77:: Delta VM: Avail -90 -> 134176843 MB, Used +4 -> 1530 MB, Peak +7 -> 1533 MB; RAM: Avail -3 -> 18124 MB, Used +17 -> 1528 MB
  ' 1:< GUI Resource Usage GDI: Avail 9032, Used 968, User: Used 446
  ' 1:< API_SUCCESS { Registering Idling event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
  ' 1:< ::77:: Delta VM: Avail -399 -> 134176445 MB, Used +306 -> 1837 MB, Peak +307 -> 1841 MB; RAM: Avail -130 -> 17994 MB, Used +332 -> 1860 MB, Peak +312 -> 1863 MB
  ' 1:< GUI Resource Usage GDI: Avail 9032, Used 968, User: Used 430
  'C 08-Sep-2023 15:00:43.172;   1:< Notify Active View.
  ' 1:< ::77:: Delta VM: Avail -65610 -> 134110836 MB, Used +58 -> 1896 MB, Peak +65 -> 1906 MB; RAM: Avail -590 -> 17404 MB, Used +43 -> 1903 MB, Peak +50 -> 1914 MB
  ' 1:< GUI Resource Usage GDI: Avail 8971, Used 1029, User: Used 463
  ' 1:< API_SUCCESS { Registering ApplicationClosing event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
  ' 0:< ::77:: Delta VM: Avail -9 -> 134110828 MB, Used +5 -> 1901 MB, Peak +2 -> 1909 MB; RAM: Avail -66 -> 17338 MB, Used +6 -> 1909 MB, Peak +4 -> 1918 MB
  ' 0:< GUI Resource Usage GDI: Avail 8971, Used 1029, User: Used 463
  'H 08-Sep-2023 15:10:51.217;   0:<
  Jrn.Data  _
          "APIStringStringMapJournalData"  , 0
' 0:< ::77:: Delta VM: Avail -167 -> 134110661 MB, Used +166 -> 2068 MB, Peak +161 -> 2071 MB; RAM: Avail -180 -> 17158 MB, Used +174 -> 2084 MB, Peak +168 -> 2086 MB
' 0:< GUI Resource Usage GDI: Avail 8963, Used 1037, User: Used 480
'C 08-Sep-2023 15:10:52.253;   0:< License Idle: Enter
  ' 0:< ::77:: Delta VM: Avail +13 -> 134110674 MB, Used -46 -> 2022 MB, Peak +6 -> 2077 MB; RAM: Avail +171 -> 17330 MB, Used -44 -> 2040 MB, Peak +6 -> 2093 MB
  ' 0:< GUI Resource Usage GDI: Avail 8961, Used 1039, User: Used 474
  'C 08-Sep-2023 15:14:16.446;   0:< License Idle: Exit
  'E 08-Sep-2023 15:14:16.446;   0:<
  Jrn.AddInEvent "AddInJournaling"  , "WpfWindow(_this,Dynamo).WpfListBox(0,recentListBox).SelectItems(1,Dynamo\.UI\.Controls\.StartPageListItem)"
  'E 08-Sep-2023 15:14:16.448;   0:<
  ' [Jrn.WpfEvent._this.recentListBox] Rvt.Attr.WindowType: WpfWindow Rvt.Attr.WindowName: _this Rvt.Attr.ControlType: WpfListBox Rvt.Attr.ControlName: recentListBox Rvt.Attr.Action: SelectItems(1,Dynamo\.UI\.Controls\.StartPageListItem)
  ' 0:< ::79:: Delta VM: Avail +33 -> 134110708 MB, Used +38 -> 2061 MB; RAM: Avail +24 -> 17354 MB, Used +40 -> 2080 MB
  ' 0:< GUI Resource Usage GDI: Avail 8961, Used 1039, User: Used 470
  'E 08-Sep-2023 15:17:19.284;   0:<
  Jrn.AddInEvent "AddInJournaling"  , "WpfWindow(_this,Dynamo).WpfListBox(0,recentListBox).SelectItems()"
  ' [Jrn.WpfEvent._this.recentListBox] Rvt.Attr.WindowType: WpfWindow Rvt.Attr.WindowName: _this Rvt.Attr.ControlType: WpfListBox Rvt.Attr.ControlName: recentListBox Rvt.Attr.Action: SelectItems()
' 0:< ::81:: Delta VM: Avail -44 -> 134110664 MB, Used +70 -> 2132 MB, Peak +69 -> 2146 MB; RAM: Avail -320 -> 17035 MB, Used +65 -> 2145 MB, Peak +68 -> 2162 MB
' 0:< GUI Resource Usage GDI: Avail 8960, Used 1040, User: Used 475
'C 08-Sep-2023 15:26:54.053;   0:< Notify Active View.
' 0:< ::81:: Delta VM: Avail +2 -> 134110666 MB, Used +2 -> 2134 MB; RAM: Avail -361 -> 16674 MB, Used +1 -> 2147 MB
'C 08-Sep-2023 15:39:57.956;   0:< Notify Active View.
'C 08-Sep-2023 15:44:59.639;   0:< Notify Active View.
' 0:< ::81:: Delta VM: Avail -20 -> 134110646 MB, Used +1 -> 2136 MB; RAM: Avail +8 -> 16682 MB, Used +1 -> 2149 MB
' 0:< GUI Resource Usage GDI: Avail 8960, Used 1040, User: Used 476
'C 08-Sep-2023 15:47:00.366;   0:< Notify Active View.
The Dynamo log for the same timeframe certainly seems odd to me, but since I can’t say I’ve ever opened a dynamo log before today… who knows i could be wrong :smiley:
2023-09-08 02:49:21Z : Active view is now STARTING VIEW
2023-09-08 02:49:21Z : The RunButton is disabled because Dynamo is not bound to the current active document.
2023-09-08 02:50:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 02:51:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 02:52:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 02:53:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 02:54:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 02:55:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 02:56:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 02:57:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 02:58:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 02:59:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:00:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:01:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:02:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:03:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:04:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:05:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:06:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:07:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:08:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:09:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:10:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:11:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:12:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:13:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:14:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:15:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:16:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:17:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:18:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:19:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:20:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:21:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:22:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:23:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:24:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:25:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:26:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:27:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:28:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:29:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:30:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:31:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:32:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:33:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:34:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:35:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:36:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:37:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:38:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:39:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:40:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:41:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:42:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:43:09Z : Backup file is saved: C:\Users\Brookepeterson\AppData\Roaming\Dynamo\Dynamo Revit\backup\Issue Family to librarys.dyn
2023-09-08 03:43:22Z : Generative Design (id: DFBD9CC0-DB40-457A-939E-8C8555555A9D) extension is removed
2023-09-08 03:43:22Z : IronPythonExtension (id: D7B449D7-4D54-47EF-B742-30C7BEDFBE92) extension is removed
2023-09-08 03:43:22Z : DynamoPackageManager (id: FCABC211-D56B-4109-AF18-F434DFE48139) extension is removed
2023-09-08 03:43:22Z : Goodbye
“'edit - sorry forgot to mention- this was Dynamo for Revit.
Also worth mentioning, I’m not overly fussed right now, I’m back to working fine. Lost a few hours but not the end of the world. I was just more curious about any changes that might have occurred that made me log out/in and accept the new license agreement and then everything was great again. Don’t stress about it”
What was the first timestamp in the Revit journal?
I’m happy to DM you the files if would like them?
Revit Journal file started at 2:45pm
Dynamo log file started at 1:47pm (This in itself seems odd to me?)
Start of Revit Journal:
' 0:< Initial VM: Avail 134213284 MB, Used 25 MB, Peak 25; RAM: Avail 20128 MB, Used 62 MB, Peak 25
' 0:< GUI Resource Usage GDI: Avail 9999, Used 1, User: Used 1
'C 08-Sep-2023 14:45:46.263;  started recording journal file
' Build: 20221122_1550(x64)
' Branch: RELEASE_2023
' Release: 2023.1.1
Dim Jrn
Set Jrn = CrsJournalScript
'C 08-Sep-2023 14:45:46.263;  ->desktop InitApplication
'C 08-Sep-2023 14:45:46.279;  <-desktop InitApplication
'C 08-Sep-2023 14:45:46.279;  ->desktop InitNativeInstance
' 0:< ::0:: Delta VM: Avail -3 -> 134213282 MB, Used 25 MB; RAM: Avail -17 -> 20112 MB, Used 62 MB
' 0:< GUI Resource Usage GDI: Avail 9999, Used 1, User: Used 6
' 0:< Options::loadOptions: m_strDataLibraryLocations=2023_Content=..\..\..\Users\
Start of Dynamo Log:
Dynamo log started 2023-09-08 01:47:57Z
2023-09-08 01:47:57Z : Python template set to default.
2023-09-08 01:47:57Z : Dynamo -- Build 2.16.1.2727
2023-09-08 01:47:57Z : System.InvalidOperationException:
2023-09-08 01:47:57Z : There already exists an AlsoKnownAs mapping for DSCoreNodesUI.Logic.If.
2023-09-08 01:47:57Z : There already exists an AlsoKnownAs mapping for If.
2023-09-08 01:47:57Z : Duplicate migration type registered for SunPathDirection
2023-09-08 01:47:58Z : launch darkly initalized
2023-09-08 01:47:58Z : LD startup time: 1075
2023-09-08 01:47:58Z : <<<<<InitDone>>>>>
Dynamo uses UTC, Revit uses the local system time.
My guess is it was an authentication issue (hence the sign in), or network issue. Can’t confirm though.
Yeah, no stress
Cheers mate
