hello
My main goal is to find the edges(in form of curves) of floors that don’t have walls the logic I made is that to found the bottom curves of the wall and find similar curves in both lists (floors& walls) and exclude the similar curves to get the edges that don’t have walls.
I need to have these following (green lines) curves ( from corner to corner) in the wall curves list so that I can compare this list with the floor edges.
i did find some but the problem I am facing is the walls don’t start from one corner and end at other corners. they start like red points:
but the curves I am getting are these.
because the walls don’t start from corner to corner and doesn’t overlap
how can make walls in a way that I get the curves from corner to corner?
please don’t suggest a solid curve intersection I have tried it and it’s not usable in my case.
thankyou in advance.
