Views Aren't Being Placed on Sheets
I am trying to use Dynamo to create views from levels, then create sheets based on the view names, and finally place the views on the appropriate sheet. I am able to successfully create the views and sheets but when I attempt to place the views on the sheets, I get a null result and the sheets remain empty. All of my watch nodes show that I am getting the desired outputs up until the Tool.PlaceViewsOnExistingSheets node. There must be something that I am missing. Has anybody experienced this before? How were you able to fix it? Any and all help is greatly appreciated!
Create Views and Sheets by Level_2021-02-12|690x331
@Colton_Haney Welcome to the Dynamo community.
Try passing equal number of points using this:
@AmolShah That fixed it! Thank you so much!
