I am getting a null
i have around 341 drafting views that i want to put on the sheets that i am making
i got the file path with the title and number correct and all the views up but cant seem to get the sheets going.
i might be putting around 15 views per sheet
and also positioning them from each other.
can someone help me!!
anyone?
Hi @mojeeb578,
When i do a search in the Dynamo Dictionary the node you are using can only place one view (on multiple sheets).
See the link below (In Depth comment):
http://dictionary.dynamobim.com/#/Revit/Views/Sheet/Create/ByNameNumberTitleBlockAndView
http://dictionary.dynamobim.com/#/Revit/Views/Sheet/Create/ByNameNumberTitleBlockAndViews
I hope it helps.
Kind regards,
Mark
Hi what i would suggest is create sheets (blank) and apply this to get you after.
Its much flexible in the long run coz you may have an idea how many sheets you creating at the start but maybe views are not created yet.
