Variable String to Text
Hello all,
I am kinda new to Dynamo. I am using it in Civil 3D (been using in Revit for a while as well).
What I am trying to achieve is the following:
I have a polyline with 4 points. I want to indicate elevation at each point. I have a dynamo file and elevations are extracted. what I want to do is to make a text, which will display elevation at each point along the polyline.
I hope I have explained myself clearly.
Hi @IrakliA
Thank you so much. Now I have another problem:
Once I convert Z elevation (rounded to two digits) to string (object to string node), string gets too many trailing zeros. for example: z is 810.88, after converting to string, it becomes 810.88000000. Do you know how can I get rid of these zeros?
String.Replace node will help there.
You’re welcome! Follow @jacob.small Suggestion.
And don’t forget to mark the post as solved.
Why don’t you use COGO points?
