Good morning,
I’m creating a routine in Dynamo where it slices the solid into layers, takes these layers, and changes the color and layer, placing them on layers where their base and top elevations are specified. However, these elevations are coming with too many decimal places. Can someone help me simplify this?
Math.Round should do the trick. ![]()
Hi
Use String.Remove node
Or you can use the Arkance Systems Node Library, that contains a node to convert a numeric value to a string with a given number of decimals.
