Numbers to string?
How do I remove trailing zeros when converting Doubles to string?
Second question: where is the documentation fo the node: “Element.ToString”?
Thank you!
The trailing zeros are specifically because you’re converting from a double. Instead, convert to an integer first (Math.Floor is an easy option) and then convert to a string.
As for node documentation, right-click the node then Help. Or you can look up nodes on Dynamo Dictionary.
Dynamo Dictionary - Element.ToString
Great, thank you.
However, how do I go from 10.5000 to “10.5”?
Also, the Dynamo dictionary has no details on the nature of the data to feed that node.
Thank you.
String.Replace “0” with a “ ”, then use a a String.TrimTrailingWhitespace, then replace the “ ” with a “0”.
The dictionary hasn’t been updated since about Dynamo 2.4 - maybe older. Documentation can be found in the product now instead - place the node, highlight it, and hit F1 (might pull up the Revit help too) or right click and select ‘help’.
This has been a discussion on the forums for at least the last decade… anyhow - there’s a node for that; Spring Nodes Number.ToString
Also fairly trivial to accomplish with python
yeah, NumberToString was not working, for some reason…
hope this paints a clearer picture.
seems like although it’s showing the decimal values, it does not seem to affect the output.
not sure what it does when setparam to the parameter values on revit though.
