Using dynamo to automatically place electrical switches next to door openings
Hey there. I have seen videos that placing switches next to door openings is possible. As well as sockets. I have never used Dynamo before. Any guidelines where should I start from to achieve what I mentioned?
Hello! Welcome to the forum! It looks like there are a few posts on this topic already. I would check out the linked post below to get you started on your task.
For further investigation and future scripts, I would look at other posts on the forum, the Dynamo Primer, and Revit API Docs if you start working with custom Python nodes.
Hi @Tecker …do you want to do it on active spaces or linked room…then i have something here as @tim.ingle mention…it can easy be modified so it could work on active room as well…
the example here is on linked rooms…hope it could help…
and for facebased families…Placing a face based family next to a door - #3 by vc98BY9
You could try this video from @GavinNicholls ,not sure it show placement with respect of doorhinge and sving…but could be a good start as well…https://www.youtube.com/watch?v=bvxeY60VGT8
I have a linked construction file so in linked room, yes. And families are face based.
