I am trying to find a way to remove/trim intersecting curves. I have the ceiling outline boundary (purple color), and I would like to cut and remove the ceiling pattern that crosses the ceiling boundary.
Turn the boundary into a surface, then use a Geometry.Intersect to get only the parts of the lines which touch the surface.
@jacob.small I am not sure where I am going wrong. I created a poly surface from the Boundary Lines and used Geometry.Intersect node but I end up with the same issue.
