When I try to run this script I keep getting this traceback error. I found a post that said this Genius Loci Tag node fixes that error, but I’ve had no success. What causes this error? It’s always the last node that is failing. I also tried the spatial element node with Orchid, and it just yielded nulls (and crashed a few times…).
The traceback is saying that the object has no Id. This is in Revit 2021, Dynamo 2.6
Tried flattening my input lists, and I still get errors, this time, “ToXyz”
Hey,
Could you show us the outputs from the nodes going into the create tag node?
Cheers,
Mark
Add a Flatten node after All Elements of Category+ and after Room.Location nodes
I replicated your issues…
Then I threw in 1 room pruned out unplaced rooms which were giving nulls in the location and then it worked
Then I plugged back in all the rooms, and it didn’t work.
Then I tried running with each room in a sub list and each set of rooms and locations in a matching sub list and running at level 2, also no luck.
I’ll let Alban take over from here
After implementing that, I get this error:
Any ideas? I’m stuck for now…
Please show us all the previews under the inputs of the Create Tag node.
There are some nulls but even when I tried cleaning the list of nulls I got the same error.
As Mark had pointed out, you have to filter out the unplaced rooms. (with a List.FilterByBoolMask for example)
You can’t tag them.
I did that a different way before, but decided to try a new node that will only collect placed rooms and it worked! Thanks everyone!
