I m trying to get a script working that should tag all rooms on all views. below is the Dynamo and python code. Im getting an error message in line 50 expected LinkelementId got ElementId
Does anyone have a hint how to solve this?
Wouter Hilhorst
import System
clr.AddReference(“RevitAPI”)
from Autodesk.Revit.DB.Architecture import *import traceback
TB =
views = UnwrapElement(IN[0])
category = UnwrapElement(IN[1])
tag = UnwrapElement(IN[2])
catid = UnwrapElement(IN[3])#bic = System.Enum.ToObject(BuiltInCategory,catid)
output =
#y=“nee”
try:
for v in views:
if not v.IsTemplate:
elementCollector = FilteredElementCollector(doc,v.Id).OfCategory(BuiltInCategory.OST_Rooms)
tagCollector = FilteredElementCollector(doc,v.Id).OfClass(SpatialElementTag)
#output.append(v.Id)
notTagged =
for e in elementCollector:
tagged = False
for t in tagCollector:
if t.Room==e:
tagged = Trueif not tagged: notTagged.append(e) for e in notTagged: doc.Create.NewRoomTag(e.Id,UV(e.Location.Point.X,e.Location.Point.Y),v.Id) t.ChangeTypeId(tag.Id) output.append(t)TransactionManager.Instance.TransactionTaskDone()
except: TB.append(traceback.format_exc())
OUT = output,elementCollector,tagCollector,TB
