toRoom, from Room nodes not working
im trying to get the information “toRoom” from every door in project.
Im using RVT2023.
Nodes from different packages not working. The output is null.
I have tryed clockwork, GeniusLoci and Crumpel.
Other nodes from packages seams to work (i have only tryed some, for example IsOddNumber from clockwork)
Is there maybe a problem with old packages? I use RVT2021,2022,2023 and 2024 on the same pc.
grafik
Any help would be great!
toRoom.dyn (24.0 KB)
At least for Clockwork you‘ll have to install the IronPython package to work in newer versions of Revit.
Thanks to Andreas, i installed IronPyhton 2.7 and now it works.
