i have 7 units as linked models, and i want to tag all the windows in the elevation views, for some reason tag all (including linked elements) doesn’t work, I guess because of design options,
so i’m trying to use dynamo, but it won’t work, any idea what’s wrong? thanks
trust me, i may not know dynamo that well, but i know revit well enough lol
it doesn’t work and i guess it’s cuz of each link has 5 design options
but thanks anyways!
It seems like since Revit 2018, it’s possible to tag linked elements;
You can try with the node “Create Independant Tag” from Genius Loci package.
Konrad_K_Sobon
Mar 22
@Dimitar_Venkov yes, Revit 2018 has a new method called IndependentTag.Create() where you can supply a Reference() to an Element in a linked file. This is new and was not available via API in earlier versions. I think it’s in 2018.0 as well not just 2018.1. Previously the only elements that had a special method for tagging in a linked file were Rooms and the node from Archi-lab.net includes that functionality.
