Hi all,
I am trying to create a script for tagging my pipe system only when I have a difference in pipe dimension. Everything seems to work properly, except from the fact that once the script is used on another view, the tags in the first view disappear. So I can either have tags on one view or the other, but not on both.
Is there a method to preserve the existing tags?
I tried the run-sync-run procedure, but it doesn´t help unfortunately.
Although I think element binding is what causes the issue as you suggest… I tried to run → sync → close the model → open the model → run the script on another floor and… the tags didn´t disappear from the previously tagged floor!!
PS: if I would have to run the script from the Dynamo Player, how could I change the view where I want to tag?
Just to recap for future use… as pyXam said, this issue is related to the “element binding” and the solution is to run the script from the Dynamo Player. The “view” variable can be chosen through the Dynamo player, following Christian´s instructions, by right-clicking on the “view” node and marking it as “is input”.
