Tag.ByElement works, but I need more help on how it works
I decided I wanted to try and cut down annotation times for drawings - I do a lot of fire sprinkler drawings that need a lot of pipe sizes etc. So, I’ve dived straight into Dynamo. My first script I’ve created is a script to tag all pipework that has a slope of 0. This worked out pretty darn well for my first attempt.
My question is, how can I make it so the tags are created centre of the pipework, and above the pipework? Currently, they’re a bit random as to where they end up.
Many thanks for any suggestions
This is how it looks, a bit messy
And this is how I’d like it to look
You must either move the tags after they are created or use a different node with a location input to create the tags.
For example the Create Tag node :
Create Tag
hi @whitelined could you please share the script?
Don’t expect any answer if you see this
He only spend 2 hours on this forum. like four years ago.
