Auto Tag in multiple views in Revit with Dynamo
Hi there
It’s my first question in the forum so, I hope I could do it well.
I’ve been working on a graph that could help me to tag multiple elements specifically structural colums, the parameter I’m tagging is “BIMSF_Label” so I have columns with different Labels the one I’m using in this example is “S0”. By the way It’s “working”, the view selection by data shapes is working, I get the Structural columns in the views with the parameter that I want, that in this case is “S0”, but the node “Tag.ByElementAndLocation” that I’m using to tag the elements doesn’t work because it only put the tags in one view and put the tags in the same position, I mean the node “Tag.ByElementAndLocation” only get the location of one element and in that location puts all the other tags.
I couldn’t be able to upload the graph, but if some is interested, I could send it by email. thanks
I would want to get this result, thanks I will appreciate any help, best regards and happy hollydays
(104) Auto Tag in multiple views 2D 3D in Revit with Dynamo - YouTube
Hello @jorge.lopez7TCDJ and welcome here…sounds like some lacing/list level…you are welcome to send the dataset to me include rvt and i will try take a look…or better use filetransfer or whatever and just insert the link here…and im sure you will get some help…and merry xmas and happy newyear to you as well…VH Søren
Hi @sovitek I think now the script is working you were right it was about lacing and structure of the list, I hope I wouldn’t have problems it I’m making some exercise in order to see what could be the limit, I hope would be further, thanks for replying
