Sweep Doesn't follow the path
Hii Guys,
I’m trying to create stair railing as shown in image below using dynamo
the problem that highlighted curves in railing path couldn’t be applied by ordinary railing tool in Revit
So I’m trying to create sweep along path as shown but the sweep result doesn’t follow the path in right way, also i don’t know how to create the a/m curves in railing path, could anyone help please ??
Maybe this helps.
Thanks a lot for your responding but still can’t get the point
I’ve tried to use the same way that was used in video but i have got a bad result as shown below
The dynamo code and the test project (using Revit 2019) are attached
Home2.dyn (34.9 KB)
Railing test.rvt (1.4 MB)
Please any help @Marcel_Rijsmus , @Alban_de_Chasteigner @Kulkul
Hi @abdallahzakaria
Solved!
Happy New Year 2020.
My First Solution on Forum in the year 2020. Many more to Come…
happy new year :star_struck: :star_struck:, you are the one :laughing:, thanks a lot :partying_face: :partying_face:
Thanks alot @Kulkul. Now, I’m trying to create a mass with the geometry we have created, but i get non editable mass, is there any way to make it editable and to be clear without meshes as shown below
Use springs Family.InstanceByGeometry custom node.
Thanks a lot, but could you suggest what is the best family category that would be used for performing such a geometry
Generic Model Category.
what package contains “Point.SortByCoordinateXYZ” ?
It’s from " Chynamo " Package
