Dynamo and Sweep Issue!
Greeting dear all,
I am making a basic sweep in Revit, it made of 2 lines and then I filleted the corner to make a curved corner, and when I select the sweep to Dynamo, I get a circle instead of a curved corner!!
Any idea why?? and what is the solutions??
Many thanks to you in advance
The original sweep before I imported the geometry into Dynamo is shown below
looks like a known old known issue:
Thanks Michael, so is it an un-fixable bug in Dynamo!!??
not unfixable :slight_smile: - I noted your post there on the issue, the more sample graphs and revit files the revit team has the more likely it is they can fix it.
I will attach Revit Family file, thanks
I will add it there too
Family1.rfa (348 KB)
Hi @firas007noori @Michael_Kirschner2
Might be fixable :slight_smile:
Is this what you’re trying to achieve?
YES!!! exactly!! how??
thanks
Mark the post as solved. You’re Welcome!
from Autodesk.DesignScript import Geometry as gm
doc =  DocumentManager.Instance.CurrentDBDocument
#Input
f = UnwrapElement(IN)[0]
# Get Profile and sketch path of sweep
path = gm.PolyCurve.ByJoinedCurves([l.ToProtoType() for l in f.PathSketch.Profile])
profile = gm.PolyCurve.ByJoinedCurves([l.ToProtoType() for l in f.ProfileSketch.Profile])
# Build the solid....
OUT = gm.Solid.BySweep(profile,path)
Mate!! I cannot thank you enough!!!
I do really appreciate your help.
I am wondering what do you advise to learn Python!!??
I am an architect and I teach Computer Graphic Application at Uni, I have my YouTube Channel teaching AutoCAD, Revit and Dynamo for free, now after this curve issue I will start focusing on Dynamo and Revit in the same time. so if you have an architectural source for Python or anything you recommend, I will be more thankful :slight_smile:
This would be a good start for you:
Many Thanks dear Kulkul
