Hello everyone,
I’m currently working on my thesis project. I worked on an adaptive component that works with the sun position. As far as the adaptive component location node is not working in an architectural template, I recreated my project in a conceptual mass template and applying the script from there. The scrypt is working fine (here you find it attached) but now i want to export an animation that shows the behaviour of the components throughout a day. In the conceptual mass template apparently I can’t export any animation as the option is greyed and in a camera view the dynamo script doesn’t work. I saw in the forum many animation as i will like to export, but can’t find a way to do it (and it seems that from revit 2017 the option for the sun path is anavailable in masses).
Thank you for your further replies.
