Hello everyone.
I was following the tutorial from Jeremy Roh about rotating panels. It worked well for in the conceptual mass template as he did in his tutorial, but actually, when moving to an architectural template and recreating the curtain panel (created the mass, i divided the surface and added the panel pattern based family). When running the script Dynamo shows the third node (adaptive component location) as an empty list of elements. Someone can address the error?
The only thing i can imagine about is that in the project template revit doesn’t use a proper coordinate system as it does in the massing template.
Thank you for your further replies.
