Hi everyone,
I’m following this tutorial https://www.youtube.com/watch?v=Bwwm13BT6kk&t=2199s
It uses a different version of Revit and Dynamo than me, and I am getting errors because of that.
When I try to get the location of the family using the AdaptiveComponent.Location node I get only empty lists, different from what shows the tutorial/
So then I tried to use the FamilyInstance.Location node. However I am obtaining a pattern of points that is also not like the one on the video.
I just want to be able to control an parameter in this family using the sun location
Does anyone knows a workaround on this?
Yna_Db
September 28, 2017, 10:22am
2
I don’t know anything about this tutorial but you will find an interesting video on this topic in the advanced tutorials here (see UNIT 6: SOLAR ORIENTATION):
http://dynamobim.org/learn/
I had the exact same problem as you. The tutorial requires a bit of tweaking on the newer versions of Revit and that’s why you’re stuck. Granted I’m stuck at a later point in the whole process, here is how I solved this particular issue (my files are in the post below, just select the Mass and use your adaptive panels)
Cheers
So I wanted to practice my Dynamo/Revit skills and thought that making a kinetic panel would be cool (it is). But after many errors and some much appreciated help from the forum I managed to make it work. Or so I thought. Literally half of my panels work. Here is what I mean:
[good 1] [2] [1]
I am utterly baffled. Would appreciate it if someone could figure out what kind of dark magic this is and explain it to me.
Here are the files and code i used:
Al Bahar.dyn (116.1 KB)
albaharpaneladapti…
I’m in the same situation. Have you solved something?
Hello everyone. This is my first post in the forum. I am trying to extract the points of my adaptive components to link the normals ones with the solar system so that according to whether the sun is giving them or not my adaptive elements are opening or closing.
The problem is that I can not get the points. All this in a project environment.
If I nest my geometry inside the mass in edit mass my dynamo routine does not read me the location of the points.
But if the geometry I insert it without…
